Fuel Economy: LS1 swap vs. EFI kit?
Old 09-20-2014, 12:03 AM
Atheria's Avatar
Default Fuel Economy: LS1 swap vs. EFI kit?
Salutations, people of the internets. I have a question I was hoping you people more knowledgable than I could answer; from a fuel economy perspective, is swapping an LS series engine into a car, for the sake of the question, let's say a 1969 Firebird with a 350 Cubic Inch Chevy motor, better (read more efficient) than adding a fuel injection kit to that 350 Chevy? I know a lot of your milage has to do with how heavy your right foot is and if you have a manual or an automatic transmission, but, disregarding those, or assuming they are the same regardless of engine, which offers better mpg's?
Sorry if this is the wrong section, I'm new here.
Old 09-21-2014, 10:58 PM
Mercier's Avatar
Modern technology(LS) really is that much better. If you want MPG, go LS. Heck, an LS motor will make more power while getting better MPG. The fuel injection only accounts for some of the improvement. Even carbureted the LS just makes more power with less fuel and BS because it is the true evolution of the Chevy small block.
Even the smallest LS, the 4.8(about 290 cubic inches) would make more power and get better mileage than that 350(5.7L)
Old 09-21-2014, 11:50 PM
Atheria's Avatar
Thank you for taking the time to reply. I'm curious though, as to something you mentioned. Would a carbureted LS really be noticeably more fuel efficient then an older 350, assuming they have the same carb? Why is this?
Old 09-22-2014, 12:07 AM
Mercier's Avatar
Roller cam(and lifters), superior factory aluminum head design, better cylinder sealing, better machining on everything..plus when maintained and treated well, they are designed to run well for over 250K miles.
A carb, if really tuned well and not oversized, will get very good mileage with a stock to mild LS1 IMO. If you throw a Dominator on there though MPG would be out the window. It's not the same as putting big injectors..if you want over 500HP and MPG then I would say you are probably better off with fuel injection and paying a good tuner.
That being said, LS fuel injection has been easy and kind to me and is cheap and reliable/predictable. It's worth it even putting MPG and power aside.
Quick Reply: Fuel Economy: LS1 swap vs. EFI kit?
