Sealed Power LS pistons 6.0
Category: Accessories
Price: $450
Location (State): NJ
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
They are designed for LS2 compression, which I am pretty sure is 10.4 to 1. They can be installed in either an iron block or aluminum. They are also .30 over pistons so your block will need to be bored. These pistons have full floating wrist pins as well and come with rings.
I purchased an LQ4 iron block that I was going to swap into a 2nd gen TA and bought these pistons to bump up compression. I decided to scrap the project and have no use for these now. 380 shipped
2, im including rod bearings and main bearings, standard size
3, your link is for press fit wrist pins
4, i didnt purchase from summit racing, nor did i realize they carry them, so i probably paid more
Didn't mean to come off as an ***. All I did was google the part number listed on your box. Came up with all sorts of hits but none list that part number as a floating pin. Did you special order?
Again...not trying to start anything but your ad should be for a bottom end rebuild...not for a piston sale. The price would be more in line. I personally would be interested in making an offer on pressed pin pistons without the bearings. I have to go .010 on the crank of my 6.0.
they were special ordered through my machine shop, i was looking for gen 4 6.0 pistons because they had the full float wrist pins.
I can sell you just the pistons if you want, without the bearings, i dont have a problem with that. but they are the full float so its up to you.
and yeah my apologies it came off as you were trolling my thread, but understandable, again sorry as well.
