New TH400 installed... Is this normal?
Old 09-27-2014, 04:12 PM
Suprslo x's Avatar
Default New TH400 installed... Is this normal?
A little background first. The car is a 99 SS 6.0 turbo car (10 lbs). The trans is brand new RPM trans, rmvb, trans brake. FTI stall. This is my first time driving with it since I got it home from the shop that installed it for me.
After installed, the car was tuned at a dragstrip. It performed flawlessly all day. I never drove it, one of the shop guys did. So I get the car home and drive it basically for the first time. When I shift from 1st to 2nd, there is very little to no RPM drop. It sounds like I didn't even shift. 2nd to 3rd the RPM's drop about 700 and keep pulling just fine. Is the 1-2 shift normal? At WOT it is the same.
Old 09-27-2014, 04:14 PM
Suprslo x's Avatar
Also, I called rpm and they basically said it's the converter and is normal. It just doesn't seem normal.
Old 10-04-2014, 12:05 PM
Camaro396's Avatar
Can you feel it shift? That is normal for big converter transmissions. Mine you can feel shift, but it wont drop any rpm, will just pull harder. Pretty cool feeling IMO.
Old 10-06-2014, 11:39 AM
Suprslo x's Avatar
I can't feel it shift. It feels like a 2 speed trans. Watching some of the videos of it at the track you can hear it shift. Maybe I'm just paranoid and unfamiliar with it.
Old 10-06-2014, 11:55 AM
Camaro396's Avatar
I don't know, I can feel mine pretty good. Infact the 1-2 is kind of violent feeling, especially under some throttle. 2-3 is a little softer, but I can steel feel that. Mine doesn't drop any RPM, but you can defiantly feel it shift. But who knows, maybe your valve body or trans is set up different. If it's running the number at the track I guess I wouldn't worry about it....You could have broke the 2nd gear sprag and it's just staying in 1st when you shift to 2nd. Post a video if you can.
Old 10-14-2014, 04:44 PM
fastlt1's Avatar
Who did the swap
Old 10-18-2014, 07:59 PM
M.BOZZ's Avatar
I have a Jakes stage 2 th400 with a 3600 stall and shifts the same as op.I have over a dozen track pass' s and just fine, but a video would be nice
Quick Reply: New TH400 installed... Is this normal?
