Need schematic for Lonnies dual hotwire harness
I need a schematic for Lonnies hotwire for his double pumper kits. I bought a E85 dual pump kit used from someone and haven't received all the components to the hotwire portion. I finally received the relays but didn't get the hobbs switch and harness or the fuel sender harness. Something is not correct and I couldn't find anything after a lengthly search. I can patch in the harness if I just had a schematic. Thanks!
I just want to say that Lonnie absolutely rocks. He took a look at the picture I emailed him and had my issue resolved in matter of a few minutes. A previous owner of my car had changed the factory fuel pump wiring harness, I found the correct harness end at Napa and soldered it into place. The car fired right up. I still need to wire up the nitrous activation to the second pump but so far my fuel system is worked perfectly on a test drive tonight, plug and play just like advertised. Lonnies Performance is clearly superior when it comes to support and customer service. Thanks again Lonnie! You have certainly earned my business, I sincerely appreciate the support and quick solution.
