Fuel Pump for 2006 Sierra
So after trying to email racetronix what seems 14,755 times, maybe I can get some answers from you guys. I want to run a 255 walbro pump in my 2006 Single cab, to feed my 4.8 w/ on3 single turbo. I really like there f99 kit they have for the 99+ fbodys, and I swear I came across a thread saying that Fbody kits would work in my application. Just wondering if this is correct.
In anycase, I know the Gss340 pump will work for my truck, but on summit, they do not come with the install kit, just wondering if anyone knows which kit I would need?
Also, is there a kit that keeps the factory venturi instact also?
Thanks!
Thanks!
8 Second Truck Club
Your 06 truck is likely a returnless system. So, you'll either need to address that, or make sure the pump is plumbed to work with the factory regulator in the tank.
I used to run a 255 pump in the tank on my 06. I kept it returnless for a while and was able to get my hands on a fitting from magnason (the supercharger company). It is a fitting that is supplied in their late model truck supercharger kits.
A return style system is much prefered if you wanna go that route.
Well now I'm kinda leaning towards the stock flex fuel pump for reliability reasons. I don't really ever plan on making anything more then 500ish which hear the flex fuel pump can handle.
