Drag Racing Tech - Where should I shift?
Sally 5.0!
12-07-2001, 04:32 PM
I have at 5.0 with heads, cam, intake...basically all the mods minus a power-adder on a stock 302 block and 3.73s.
Here is dyno sheet from LG.
http://sally.cz28.com/images/sally.jpg
AAron
12-07-2001, 05:34 PM
depends how reliable you tach is i shift outa 1st at 5500 because it is soo far behind the rest i run it up to 6400-6500 <img src="images/icons/smile.gif" border="0"> but this is on an F-body
I can't see your dyno chart, but if I remember correctly, your mods are similar to mine. I'm guessing peak power is around 5,500 rpm, so I'd try playing with different shift points between 5,500-5,800rpm.
Sally 5.0!
12-08-2001, 03:36 AM
Yes, almost identical mods. I will give it a shot tomorrow if the weather clears. <img src="images/icons/smile.gif" border="0">
Sally 5.0!
12-08-2001, 06:45 PM
Well, the track is closed due to the dry, cold weatehr we had tonight.
Sally 5.0!
12-08-2001, 06:48 PM
This is this a link to the graph.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
