Squeak coming from the rear
Hi,
I recently bought a 2000 camaro and there is a squeak coming from the rear when I'm just driving or accelerating. The squeak goes away when I brake or am just idling. Any ideas what it is?
Check the two bolts that attach the torque arm to the rear differential. Make sure they are tight. I have had that happen. If they are loose you may want to put some lock washers or lock tight on them. Sway bar bushings will squeak too but that's usually only over bumps
