Wtt-95 z28 pro charged moser 9 inch!!!
Year: 1995
Make: Chevrolet
Model: Camaro
Price: $10000
Mileage: 90000
Private or Dealer Listing: Private Listing
Location (State): VA
Color: Blue
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Built 355 eagle rods Keith black forged piston
Cosmetic head gaskets arp head bolts
Stock ported and polished head 202/160 stainles vales patriot gold extreme springs with titanium retainers 1.6 rollor rockers
Cc306 cam new pushrods and lifters
New oild pump timing chain and gears all new gaskets moroso oil pan
Canton tall valve covers
LTCC coil conversion with 2 step and timing retard msd 8.5 wires
Billet keyed crank hub
P600b pro charger with 12lb pulley air to air front mount intercooler
Loyd Elliot ported intake 60lb injectors 58mm polished throttle body
Pacesetter long tubes heat wrapped 3inch y pipe into 4 inch muffled cutback
BMR tubular k member and adjustable upper and lower control arms
8k hid converted headlights
No a/c
New radiator
Spec stage 3 clutch
Drilled and slotted rotors
New moser 9 inch rearend 4:11gears
Abs delete with line lock
100 hp shot nitrous with bottle heater and lean cutoff switch
Polished radiator hold down and battery cover
Black leather interior factory Bose sound system new GM upper dash pad power windows/cruise all work perfectly drivers seat has a small wear in upper lumbar new blue stitched leather shift boot and armrest cover
MGW short throw shifter
New rear nitto tires fronts have are about 50 percent
Looking to trade for LS powered anything
Call or txt Keith 276/210/2580 or pm me will try to get pics of engine and interior this week thanks
