bad quality aftermarket fuel rails, what can i do ?
Hy all
finally i got my new set of fuel rails for doing a return fuel setup.
After i have checked the rails i found out that there are some small blades inside of the center whole...
For details pls check the pics...
I am from Germany so its not that easy to send it back, therefore i hope u know any solution for smoothing the rail at the inside of the center whole..
Thanks a lot
Achim
Thanks a lot
Achim
Either buy good quality rails, or just get a small file or round burr and try and clean them up as best as possible before using.
Or even some wet/dry sandpaper.
