Cheapest "built" rear end I can buy to support 700rwhp?
Trying to figure out what rear end to buy. I'm wanting something that will swap in pretty easily while reusing as many start parts as possible to keep the price down. Want something that will bolt in quickly and be ready to go. Also I want something that won't eat up tires. With all that said maybe you guys can help me figure out all the parts I want and what rear end to buy?
1. What rear end to get? 9", m9, or 12 bolt?
2. trutrac, trac-loc, or locker?
3. Is abs/tc needed?
4. 3 channel or 4 chanel abs?
5. Will most stock parts to mount the rear end to the body work or will all of that need to be purchased also?
Some say TruTracs don't last, but I have been beating the **** out of mine for probably 5k with countless clutch dumps on bias plys at the track and it has been holding up fine for an M6. A locker would be a stronger option for an auto car. Is your car 3 channel or 4 channel now? That will answer your question - or you can delete ABS entirely like I did, though people don't recommend it (I prefer it without). Stock parts do mount up with most rears...but you should definitely get a new torque arm if you don't have one as well as LCAs. Also, you're going to want to get a good driveshaft if you don't have one too. 9" is going to be more expensive but stronger, however heavier unless you are going with a MWC or similar high dollar one.
LS1Tech Sponsor
http://shop.brutespeed.com/Brute-Spe...nformation.htm
Take a look at the info I have at this link, it may answer some of your questions.
http://shop.brutespeed.com/Moser-12-...structions.htm
Installation instructions that show how a Moser rear goes together.
http://shop.brutespeed.com/Moser-9-I...c-Truetrac.htm
A nine inch with a Trac-Loc is going to be the cheapest way to go with a differential in a Moser rear. If you have just ABS you would have to go with the Truetrac. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
35 spline Truetrac is an option at this link
http://shop.brutespeed.com/Moser-9-I...h-Wavetrac.htm
Wavetrac with 35 spline
I just realized you want one that can handle 700 rwhp. The new Truetrac with 35 spline axles or a Wavetrac with 35 spline axles would be the way I would go.
__________________
LS1Tech Sponsor
I would go with the no cost optional LCA brackets. You can still reuse your stock lower control arms, you'll just have to use the higher mounting holes until you can buy adjustable lower control arms.
Everything else looks good. Thanks Zach. Bob
__________________
LS1Tech Sponsor
I agree. If most of your driving is rural or highway, the only time you'll notice the car has a spool is when you're turning in an intersection. If you try to make a u turn, you'll find the car will tend to plow forward (understeer), you can do it if you give yourself more room, just like if you were towing a trailer. Bob
__________________
Maybe with a spool itll be that price. I forgot what my s60 by itself with the s-trac cost but I paid 2900 for the rear and driveshaft shipped. I ordered it through Carl at CRP and he told me he has customers pushing 8-900hp with the strac and he hasnt had any one say anything bad about it at that level.
Op, it might be worth looking into.
https://ls1tech.com/forums/gears-axl...plus-more.html
nope http://www.centralracingparts.com/prsf05/ "call for special pricing"
I thought brute speed sold these as well but couldn't find it
another option http://www.quickperformance.com/9-Ho...ages_c_55.html
some torque arm brackets hit the floor on these non fabbed 9" housings, not sure which ones specifically but there are lots of posts on it
LS1Tech Sponsor
It doesn't happen with the Moser M9 fabbed 9 inch either. http://shop.brutespeed.com/Moser-M9-...y-Complete.htm Bob
__________________
