Brand new rpm built lvl 7 4l60e
Category: Accessories
Price: $3500
Part Fits: Corvette
Location (State): KY
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
*RPM Level V 5-6 clutch pack
*RPM reinforced sunshell with collar and bearing
*Heavy Duty double caged 29 element sprag
*4L65E low roller clutch
*Billet 4th gear servo
*Transgo HD-2 shift kit
*Corvette Servo
*Wide 2-4 band
*Updated aluminum accumulator piston
*Bushing kit
*New shift solenoids
*New GM valve body spacer plate
*Seal & gasket kit
*GM Filter
*RPM Spec clutch and band clearances
*RPM sleeved input drum
*Billet over-run piston
*GM 5 pinion planetary gearsets - front and rear
*NEW Extra WIDE Heavy Duty double caged 29 element sprag
*300m Billet output shaft
*4L65/70E low roller clutch
*Billet 2nd gear servo
*300M Billet Input shaft
*Billet Pump Rotor
*Billet Forward Piston
*2-3 HD Apply Valve
*Deep pan
*Micropolished Internal Parts
*polished gears
