Th400 lq4. Converter to flexplate gap.
I've neglected to ask this earlier, but my converter to flexplate has a gap. I used the tci flexplate and the spacer. The converter is pretty snug to turn on the motor as it's tight at the spacer. Should I just shim it and go? The converter is fully seated in the trans. Th400 and '03 lq4.
I had the same problem with my 5.3 and th350. I used three washers of the same grade and drove it without any issues for a year or so. Just make sure you have a little clearance between the converter and pump.
Yeah, I do remember sliding the spacer over the converter snout. It turned by hand, just a little snug from the paint build up, but it did go on. So yours fit flush?
Weird.
I can still turn it, it's just definetaly not as free turning as some others I've turned by hand. This is just my first lsx build. As far as moving it front or back towards the trans or towards the flexplate, no. I cannot move it. The converter is from freakshow.
http://www.jakesperformance.com/Tran..._FAQ_Page.html
How do I know the converter is completely seated?
The old "3 clicks" method is not an accurate way to determine if the converter is correctly installed.
There MUST be clearance between the converter and flexplate when the trans is bolted to the engine.
In a perfect world this would be 1/8" or .125" everytime, and you just bolt it up and go.
In the real world, we have to check it and make adjustments as necessary.
On a typical GM engine, the flexplate mounting pads are 1" away from the bellhousing flange area of the block.
The converter pads when seated completely will be approximately 1 and 1/8th inch ( 1.125")recessed into the bellhousing.
Seat the converter, then measure the distance from the engine block bellhousing mating flange, to the mounting pad on the flexplate.
Then do the same from the transmission bellhousing mating face, to the converter mounting pads.
You should have the converter sitting deeper than the flexplate protrudes from the engine.
If so, you can now bolt the transmission to the engine.
With the trans bolted to the engine, you should be able to turn the converter freely.
Check the distance from the converter to the flexplate with the converter completely seated into the transmission.
You should have 1/8" to 3/16" clearance. (.125"-.187")
If it is more than 3/16", you should use flat ground washers to shim between the flexplate and converter.
Weird.
Chris
Moderator
When you have the right converter and it is fully seated, you can easily pull the converter out to touch the flexplate and then push it back in to make the gap.
jrpimp00 has all the right and critical measurements.
As Chris mentions, if you cannot easily push/pull the converter back and forth, you have a major problem that must be solved before you trying bolting it up.
Moderator
If you cannot easily (e.g max 10 lb force) pull out the converter to touch the flexplate and "potentially" bolt up without any gap and without spacers, then something is WRONG.
The purpose for the spacers is so that the converter does not pull out so far that the pump is disengaged. Is is NOT to fill a gap you cannot close.
