5.3L vs. Milled 5.7L Heads Question.
Old 05-25-2004, 11:00 AM
yyz28's Avatar
Default 5.3L vs. Milled 5.7L Heads Question.
I've got a set of 5.7L heads milled .030 for 10:8:1 Compression. How does this compare to the COMPRESSION, Chamber size and deck heighth of stock 5.3L heads?
...I'm looking at a cam and we're trying to make sure we're ok with P/V Clearance, and we know it works on a set of 5.3's, and I've got milled 5.7's.
Thanks!
Old 05-25-2004, 12:50 PM
Suspended Sponsor Account
ForceFed HP's Avatar
hey Scott this is Scott(Demon SS) what are your cam specs? an unmilled 5.3L head would give you back your .030 and still give you a 10.8ish compression.
Old 05-26-2004, 12:38 AM
TD's z's Avatar
Compression isn't the only reason the 5.3 is the better head, chamber shape is a big factor.
