cooling fans, swap harness for ls into LT1 camaro, 799 heads, misc f body
Category: Accessories
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): MO
Item Condition: Used
LS Engine?: Fits LS Engine
Very low mile 799 heads that have been tanked and checked by my machine shop, then completely cleaned perfectly as well as a fresh lap job plus new valve stem seals installed. These are perfect and are complete bolt on ready and look amazing - $450 plus shipping
Flex-a-lite 16" puller cooling fan, was only installed on my turbo setup once and ran through one heat cycle. I paid $160 for this new when I bought it and I would like $100 out of it. Works amazing and did it's job, I just had to go with a pusher setup.
LSX swap harness for a 94-95 LT1 f-body. This harness came out of a 94 camaro z28 with an ls1 in it. It worked perfect and if anyone has looked into this swap the price to have someone match these harnesses is crazy expensive. Still has all the smog, evap and other wires and plugs on it so they can be used but is not nessecary. This harness will be perfect to just drop in and go for any LS engine into a 94-95 f body car. $250
Spare tire and Jack out of my 97 camaro SS. Shipping may be a little high on this but don't have an issue with local pickup on any of this stuff. Tire and Jack in perfect shape. $25
Rear bumper with support plastic off a green 4th Gen f body in perfect shape (not the cover but the actual bumper) $20
4th Gen coolant overflow tank in good shape $15
Perfect top piece of center console (shifter cover) out of 97-02 camaro $25
Brand new LS7 valley cover with brand new steel gasket for it used for DOD delete. I paid around 150 for both of these new I will take $115
Knock sensor delete valley cover that is new $25
Ebay t4 turbo blanket $10
6.0 ctsv exhaust manifolds w/heat shields brand new never installed $75
1998 LS1 f body ECU $50
Also have misc cooling fans in different sizes such as one 7" puller/pusher, one 12" pusher/puller and two 10" pusher/puller fans that I will sell for $15 bucks each. These are all like O'Reilly brand.
Call or text anytime for pictures of questions at 6602336251. Name is D.J thanks.
