6.0L Turbo LSx Engine, Complete
Category: Engine - Complete Motors
Price: $7500
Location (State): KY
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
K1 Crank, Rods
Wiseco Pistons, steel rings
Balanced
All Machine work done by S.A.M. (School of Automotive Machinists)
8.8:1 Compression
Holley Pan (pickup moved to back and trap door decel baffle added)
Mellings pump
ARP Head Studs
ARP Main Studs
ATI Balancer
L92 Heads, S.A.M. CNC Ported
Cometic Gaskets
Ferrea valves
Double Springs, Light Weight Steel retainers
Straub/Bullet 230/228@.050, 112 LSA .551 Hydraulic Roller
Morel Short Travel Lifters
C5R/IWIS Timing Chain
Smith Brothers Pushrods
Stock Rockers with Comp Trunnions
Holley Hi Ram Intake and Rails
120 pph Holley injectors
GM Coils
GM Water Pump (purchased new)
4 Corner Coolant AN Crossover Lines
GM Starter (purchased new)
GM Alternator (purchased new)
BorgWarner S400SX3-80 80mm Turbo, PN 179180, T4, 1.25 A/R
Hooker Cast Iron Manifolds
Hot Side Plumbing, Cold side plumbing
Precision Turbo 66mm Wastegate
Tial Blow Off Valve
Stainless Steel Hotside Piping, TIG Welded
This engine basically has 2012-2014 Drag Weeks on it. Less than 35 passes at the track. Always run with race gas at the track. Ran best of 9.34@146.6 in 3850 lb Nova this year. Building BBC.
Still in car, can hear run and drive. Have Holley EFI tune.
$7500 complete (parts listed above)
$6000 minus turbo, exhaust, wastegate and BOV
Email: dougflynn@holley.com
