Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Turbo Kit - PT76gtsh F-body **SOLD**
Old 11-03-2014, 08:55 PM
pwrtrip75's Avatar
Default Turbo Kit - PT76gtsh F-body **SOLD**
Category: Accessories
Price: $2500
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): WI
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
**SOLD TURBO**
Turbo setup off my 99 Trans Am - Im selling it to build a new one.
*edited this ad, Selling entire setup now.
Turbo, manifolds, crossover pipe, wastegate, downpipe, intercooler, BOV, cold side piping.
Precision PT76gtsh turbo T4 rated 1150HP (same as the PT7675 just older part number) h means ported exhaust housing, coated exh housing. .96 a/r
3" stainless downpipe ends at starter with v-band flange.
Truck manifolds w/ v-bands welded on,
316 stainless 2.5" tube crossover (.065 wall).
Precision 46mm gate,
Ebay 4" intercooler w/ fod light mount brackets welded on for Transam.
3" cold side piping all tig welded.
Tial 50mm BOV.
All rubber/silicone connectors (intercooler ends and TB end).
Turbo setup has less than 2000 miles on it street car with less than a dozen passes at the track. This turbo is ideal for a 5.3L and also work on a 5.7L but I would not recommend it for anything bigger unless you were not looking to push it very hard.
$2500. For All Im in Janesville, WI.
I had this setup on a couple engines in my car. Full weight stock suspension car on a 275 drag radial. 3660lbs w/ me in it.
-6.0L TU1 cam, Glide, 3.50 gears. E85 18psi went 9.6x @ 141 video in signature.
-5.3L (stock lower) TU1 cam TH400, 3.00 gears. 93 octane 14psi 10.50 @ 133
-6.0L TU1 cam, TH400, 93 octane/ 110 mixed, 3.00 gear, 18psi 10.00 @ 137 Car is still 100% together with this combo now.
Couple vids
Old 11-05-2014, 05:11 PM
DisasterpeaceWS6's Avatar
This is 4000 with me th kit? What is the price for shipping to 28540?
Old 11-06-2014, 09:22 AM
pwrtrip75's Avatar
bump...............
Old 11-06-2014, 12:10 PM
Will this work with 92mm cable tb?
Old 11-06-2014, 05:52 PM
pwrtrip75's Avatar
No.
Here is the description and part number for the intake elbow.
Ultra Low Profile Intake Elbow (up to 90mm Throttle Body) with Satin Finish #3847 by Edelbrock
Old 11-10-2014, 12:35 PM
pwrtrip75's Avatar
Bump.
Old 11-10-2014, 02:00 PM
tnmotown's Avatar
Will this work with a stock k-member?
Old 11-10-2014, 02:33 PM
95-1LE-Z28's Avatar
Bump for a sweet deal!!!!!
Old 11-10-2014, 02:45 PM
pwrtrip75's Avatar
I have a Racecraft k-member, not a turbo one. I am not sure if it will fit a stock one as I dont have one to even look at. It is a 3" downpipe, Here are a couple pics I just took under the car.
View of the passenger side front. My motor mount is notched from a previous kit I had with a 3.5" pipe, there is tons of room around this 3" pipe, but where a stock k-member is in relation to this I am not sure. Hope this helps.
Old 11-27-2014, 01:13 PM
pwrtrip75's Avatar
Bump.
Old 12-08-2014, 06:46 AM
pwrtrip75's Avatar
Bump....
Changed the ad a little, selling it all now. Complete setup. I have HP Tuners and can flash any 99 fbody PCM to a 2 bar tune, and I can put my tune in there for you for free if you want. I have the tunes from this kit used on a 5.3, 6.0, gas, and E85. It will not be a 100% tune but good enough to start the car and drive it somewhere.
Old 12-19-2014, 06:36 PM
pwrtrip75's Avatar
Price drop from $3000 to $2500. Good xmas present for someone.
Old 12-20-2014, 05:54 AM
dieselman88's Avatar
How would this setup do on a 98 ls1 trans am? Looks like you don't retain ac, was gonna paint the car this year but this kit is very tempting. Comes with everything to install, I wouldn't have to buy anything else?
Old 12-22-2014, 06:39 PM
pwrtrip75's Avatar
It would fit. Not sure what engine you have, stock LS1? It would work, spool super fast and capable of making more power than the engine would hold.
As far as buying anything else, fuel system and tuning and a MAP sensor, AIT sensor, oil feed and drain hoses and a drain fitting in the oil pan.
Old 12-28-2014, 09:58 AM
pwrtrip75's Avatar
I'd sell just the turbo for $1000. shipped
Old 01-09-2015, 07:31 PM
pwrtrip75's Avatar
bump.
Old 01-14-2015, 06:26 PM
pwrtrip75's Avatar
Bump. I'll include the oil lines and ship for the $2500.
Quick Reply: Turbo Kit - PT76gtsh F-body **SOLD**
