Cam recommendations, best performing 1/4 mile cam for stock heads?
Old 05-25-2004, 07:05 PM
9 Second Club NA
Dragaholic's Avatar
Default Cam recommendations, best performing 1/4 mile cam for stock heads?
Im looking for a cam thats going to dominate at the track with stock heads. I know of a few cams in particular that are being used to break into the 10s, but then again, they have really extreme setups. My mods are in my sig. however I plan to go with more gear and more converter hopefully soon. If I end up with a cam that has more than .600 of a lift or very close to it, I will more than likely use the Patriot dual spring kit. I want to try and get low 11s and maybe if I end up with the right setup break into the 10s with the right weather and track preperation. What cam do you suggest? Please list manufacturer, developer, and specs of cam. Thanks a lot.
(I had a similar thread to this one, but got off topic debating a particular cam. So that is why I started another.)
Old 05-25-2004, 09:50 PM
Scoobie's Avatar
Check out this link http://www.ttperformance.net/cam/mike114.mpg
These are stock LS6 heads, TTP equalizer Cam V.1. Dynoed in the 430+ range with many bolt ons through a 12 bolt, M6.
Old 05-25-2004, 10:11 PM
SMOKIN01TA's Avatar
with your weight and setup you should go 10's with the trex cam. i say that cause it pushed my tank to 11.2 in crap weather.
Old 05-26-2004, 10:44 AM
9 Second Club NA
Dragaholic's Avatar
SMOKIN01TA: What gears are you running? What are your shiftpoints and wheres your rev limiter set at? Is your bottom end built any or completely stock? Thanks.
Old 05-26-2004, 11:24 AM
Jay 95WS6's Avatar
get al cordova's cam and skip the 10's go right to the 9's lol
Old 05-26-2004, 03:29 PM
9 Second Club NA
Dragaholic's Avatar
Whats the specs on that cam? Whatever they are, theyre not going to get me into the 9s. I wish it was that simple though.
Old 05-27-2004, 02:05 AM
deviate42's Avatar
with forged internals, some nice heads, the trex and a 200 shot...youd be there
Old 05-27-2004, 02:15 AM
jrp
SN95 Director
jrp's Avatar
look at his sig. he's got 4.56 gearing and he's on the stock bottom end if i remember. i'd assume rev limiter is 7k or so as well.
Old 05-27-2004, 08:12 AM
SMOKIN01TA's Avatar
yep, what he said. rev limiter is at 7200 and i shift at 7000 for now but the cam pulls hard all the way to 7200 so i would like to shift higer than i do. however im brave, not insane. it is stock bottom end for a few more months.
Old 05-28-2004, 11:26 AM
9 Second Club NA
Dragaholic's Avatar
Do bigger cams (more duration and more lift) require more rpms to benefit from the cam? My bottom end is completely stock and the cam I have in there now peaks at 6300. I installed the cam straight up and there is no advance ground into the cam, so Im assuming thats why it peaks so late. Anyhow, if I get a much bigger cam which more than likely Im going to do, is it going to peak any lower or will I be able to shift any sooner or about the same? I shift now at 6500. Id like to have the rev limiter at 6800, but in order to allow my tranny to shift around 6600-6700, I need a little room for overshift and that would mean I need to put the limiter at 7000. Anyhow, Im still on the hunt for a cam, so any more suggestions? Thanks.
Old 05-28-2004, 11:32 AM
Orange Peel's Avatar
Take a look at the LG G5X2 for an automatic car, we have a guy in our group that has one on his TA, works great, no driving problems, etc. That may be an option, give Lou a call at LG and he will be glad to answer any questions you can think of asking, he knows his cars!! I just put the G5X3 in my car and love it, the best thing so far, pulls like a raped ape!!!!
Old 05-28-2004, 01:45 PM
Snake Eater's Avatar
T-REX!!!!!!!
T-REX!!!!!!!
T-REX!!!!!!!
If i get a t-rex will i loose my 34mpg? Ya know its all about gas milage.
Old 05-28-2004, 02:13 PM
SMOKIN01TA's Avatar
Originally Posted by Snake Eater
T-REX!!!!!!!
T-REX!!!!!!!
T-REX!!!!!!!
you would be suprised how good my gas mileage is with the trex and my gears.
Old 05-28-2004, 02:22 PM
I actualy bought my car for a daily driver so i could save the miles on my truck. Im realy impressed with the fact that a 350+rwhp car gets 34mpg. I may change up the exhaust though to get rid of the loud drone on the highway. Maybe dual bullets? Or dual magnaflows?
I would like to get it into the 10s though now that i have it. It got realy addictive. Allthe money in my truck, and the car pulls way harder on motor. Do you have any driveability probs with the t-rex around town?
Old 05-28-2004, 03:59 PM
The Juggernaut's Avatar
Hmmm,...I'm drawing a blank.
Old 05-28-2004, 05:08 PM
9 Second Club NA
Dragaholic's Avatar
I dont get it.
Old 05-28-2004, 05:22 PM
jrp
SN95 Director
jrp's Avatar
I dont get it.
did you read his sig
Old 05-28-2004, 06:16 PM
SMOKIN01TA's Avatar
i have been driving it for the last 2 hours, other than missing my a/c it was perfectly enjoyable.
Old 05-28-2004, 10:54 PM
99WS6LS1T/A's Avatar
That cam only record will soon be a void. I have knowledge of a lighter car with a little bit more "cam only" power that's on its way to the track in the next 2 weeks.
Old 05-29-2004, 02:13 AM
95LS1TA's Avatar
01-Z is your cam a 112-114?
