1999 Camaro Z28 M6 - Upgraded Trans/Clutch - 78.5k miles
Year: 1999
Make: Chevrolet
Model: Camaro
Price: $8000
Mileage: 78500
Private or Dealer Listing: Private Listing
Location (State): KY
Color: Gold
Transmission: Manual
Drivetrain: Rear Wheel Drive
All body panels are straight and paint is awesome, no body rust. The factory chrome wheels still shine and have no chipping or flaking. Interior is very clean with seats and carpet in like new condition. Non-smoker owned both times. T-top roofs do not leak! All weatherstripping is in great condition. Headlights are clear and not faded or fogged up. I also detailed the interior last fall which involved removing all seats and center console, vacuuming, and shampooing the seats and carpets.
No mechanical or electrical issues. All regular maintenance and oil changes every 3000 to 4000 miles. I had the transmission rebuilt and upgraded along with a LS7 clutch change about 10000 miles ago. All fluids were changed at that time as well. Air conditioning runs strong as well as the heater. The only things this car will need is a new muffler (still stock) and is getting ready for new front brake pads.
Of note, this car has been unmolested and remains mostly in stock form. There have been some parts replaced and small performance mods that I have had done.
Transmission rebuild performed by Street Legal Performance in Louisville, KY. The trans shifts smooth as glass and the feel is WAY better than stock. Parts make it stronger as well. Clutch feel is amazing, firm, but still very easy to use for the streets.
- Synchro rebuild kit
- Bronze fork pads on all gears 1st through Reverse (these replace the plastic ones)
- Billet stainless steel keys
- New 3rd gear spacer
- Steel fork for 3rd to 4th (replaces factory aluminum)
- Tick Performance adjustable clutch master cylinder
- GM factory LS6 clutch slave cylinder
- GM factory LS7 Clutch
- GM factory LS7 flywheel
- New GM factory pilot bushing
- ARP flywheel and pressure plate bolts
Other new parts installed:
- BF Goodrich G-force Sport Comp 2 tires size P255/50/16 (have about 12,000 miles and in good shape)
- Spicer heavy duty driveshaft U-JOINTS
- UMI Performance Torque Arm and poly bushing
- GM factory Hurst shifter with Hurst leather shift ****
- SLP Air high flow box lid with K&N air filter
- NAPA auto replacement driver side window motor
- New GM factory rear hatch struts (hard to find but fit better than aftermarket)
- New GM factory motor mounts
- New GM factory transmission mount
- New Federal MOOG steering tie rod ends
- Kee Audio Level II speaker package (installed properly and carefully by me)
Car is located near Louisville Kentucky, titled in Michigan. Will meet up to 150 miles for a sale or can pick you up from Louisville Airport (SDF). I prefer not to have the car shipped but if absolutely necessary will accommodate.
I have A LOT more pictures available upon request.
$8,000 or reasonable offers considered.
Thanks!
