NEW dual phantom 340 aeromotive
Aeromotive just released the new dual phantom last month so I'm ditching the 3 walbro that give me problems.
Just got off the phone with aeromotive and my dual phantom is on its way to me! They not sold any to summit jegs or anywhere yet so needless to say I had to pay them what they wanted.
But they said it was 799 last week and that's what there site says. But I orderd it and was only 760.I guess they dropped the price, I wonder if this means they sold some to summit now... oh well either way I got mine from them, I'm sure summit will be cheaper by $100
I will be running both pumps constantly on separate relays and the secondary pump will turn off with a vacuum hobb switch,
The advantages to the vacuum hobb is that it turn off one pump when pulling vacuum (at idle rpms) and obvious then both are running when under boost,
This way if the switch fails what happens is both pumps run..versus a fuel pump controller failing (that would leave one pump dead)
Does anybodyelse have the dual phantom yet or am I the first???
I just bought a set of 340's and im going to run them in my stock chevelle tank which ill modify instead of paying that price. It is a nice setup but I just cant afford it and ill be watching your build now. I have a 5.3 with a Hong Kong Phoey Gt45 68 mm turbo.
I just bought a set of 340's on here and im going to run them in my stock chevelle tank which ill modify instead of paying that price. It is a nice setup but I just cant afford it and ill be watching your build now. I have a 5.3 with a Hong Kong Phoey Gt45 68 mm turbo.
So I've been looking for information on the dual phanton, specifically what pressure it runs at in a supercharged EFI setup because with my setup I'll need two of them, or at least I'd preferred having the two dual phantoms over an inline pump or even a belt driven system. Thanks in advance for that info also
