D3 Performance Engineering ZR1 and Non ZR1 C6 Corvette Dual Spal Fan Shroud Kit
Closed ex-Sponsor Account
D3 Performance Engineering is proud to introduce a new product for the C6 Corvette ZR1 and non ZR1 C6 platforms, the D3 ZR1 Dual Spal Fan Shroud kit! This
product was designed to help solve common issues associated with higher HP setups using higher spun superchargers that drastically increase pre
intercooler temps which then gets transferred into the intercooler system. That heat is then transferred to the heat exchanger in the front of the car
which raises the air temps flowing into the radiator. Some of the aftermarket heat exchangers on the market can also restrict air flow to the radiator
itself. In addition to that the A/C system (condenser) introduces even more heat into the mix. The stock radiator is a high quality unit with large
surface area, high fin density, and great construction, however, once you start dealing with elevated temps and restricted airflow, the OEM fan setup
is no longer efficient at removing heat from the cooling system. While being a good flowing fan, the factory shrouding does not cover the entire face
of the radiator and we feel this leaves a lot of potential for additional heat extraction.
Our Dual Spal Fan Shroud kit includes a 3D CAD designed fan shroud built from lightweight yet sturdy .125” aluminum and featuring stainless
pressed-in mounting hardware along with air bypass flaps. Next it features the highest flowing fans available from Spal in 11” diameter. These are
not the highest “free flowing” fans, they are the highest flowing fans in a restricted state, which is what really sets different fans apart when they are
mated against a radiator.
This kit also includes the Spal relay and wiring harness kit which is designed specifically for dealing with the high current draw of these HO fans.
This kit is a 100% bolt in install and requires the OEM fan control connector to be wired to the Spal harness, power for the Spal harness connected
directly to the fuse box lug, and the ground wire connected to the chassis.
Pricing for this kit is $899.99 shipped in the lower 48 states for CorvetteForum.com members, for international shipping quotes please email or call,
dealer inquiry’s welcome. Available for C6 ZR1 and non ZR1 models.
(832) 453-0887
Sales@D3PerformanceEngineering.com
