80lb injectors, FAST 102mm TB, Methanol Injection kit
Category: Engine - Intake/Fuel
Price: $300
Location (State): TX
Item Condition: Brand New
LS Engine?: Fits LS Engine
$300
Stage 1 Competition Fender Mount Water Methanol Injection Kit [100108]
Competition 3 quart tank
250 psi pump with EPDM seals for 100% methanol or alcohol
Adjustable boost activated switch from 1-25 psi
Heavy duty check valve with quick disconnects
20 ft of black high pressure tubing
5 ft of vacuum tubing
25 ft of electrical wire
Green LED status light
Nickel plated injector
Interchangeable nozzle sized to application
Fuse holder with fuse
10 ea. 8" zip ties
5 ea 4" zip ties
Hardware for securing pump to vehicle
http://www.alcoholinjectionsystems.c...roducts_id=275
Stainless Steel Hose Kit For Trunk Mounted System, Dual Nozzle [1008]
1 - 18 ft -4 stainless steel braided hose assembly
3 - 5" -4 Stainless steel hose assembly's
1 - 3/8 NPT to 1/4 NPT reducer fitting
3 - 1/4 NPT to -4 AN adapter fitting
2 - 1/8 NPT to -4 AN adapter fitting
1 - 4 AN tee fitting
2 - Nickle plated nozzle holders
http://www.alcoholinjectionsystems.c...roducts_id=238
$450 for all
FAST 102mm throttle body WITHOUT TPS sensor - cable driven for LSX and LSX-R intakes. Part # 54102
$400
