F/S Ross, NX, Aeromotive, Eaton, Reichard Racing
Category: Accessories
Price: $75
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): AL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Ross Pistons with/stock rods – 4.030, ring sizes 1.5mm, 1.5mm, 3mm, nice used set, comes with OE used rods - $325
TCI Converter 242101 used perfect working condition, 10” 3200 Stall Perfect for street and strip I used on TH400, should also work with TH350 and Powerglide - $325
Nitrous Express used Gemini Twin Stage 6 Nitrous Plate NP604 for 4150 manifold. Comes with lines and jets, 100, 150, 200, 250, 300, new plate with jets lines and fitting will cost over $400 - $250
Nitrous Express New (NX) NP408 - Nitrous Express Hitman Conventional Plate, comes with lines and fittings, $110
Aeromotive 12304 - Aeromotive Fuel Filter 100 microns, perfect working condition, I am upgrading to larger inlet, this work up to 10an and small as 6an with proper fittings - $75
Aeromotive 13109 - Aeromotive A1000-6 Injected Bypass Regulators – used, perfect working condition adjustable from 45psi to 75psi No fittings, - $100
Aeromotive 13101 - Aeromotive A1000 Injected Bypass Fuel Pressure Regulator Almost New, was used for mock up only adjustable from 45psi to 75psi - $110
Reichard Racing Billet Aluminum Vacuum pump mounting bracket for 3 vane Moroso vacuum pump. This will bolt up to stock A/C bracket and use AC Belt to drive pump. This will fit on corvette or F-body. (F-body will need c-notch on frame to clear pulley) $125
Moser Engineering 5E12334 - Moser Engineering Eaton Posi Unit, Used for less than 3000 miles
$300
will split shipping cost.
badls12000@yahoo.com
Harry
