Siemens 60lb injectors cylinder matched by Tony Mamo/LS3 fuel rail
Category: Accessories
Price: $275
Location (State): IL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
Siemens 60lb Injectors-These injectors came with an engine setup I purchased from Tony Mamo. These were for an 'attention to every little detail' build for his personal car. These were flowed and matched with the proper cylinder by Tony. I purchased everything assembled. They were labeled as they were removed so that they can be matched properly with the apppropriate cylinder. These are the EV1 style connectors as I had to buy adapters to use them with my LS7 (I have EV1 to EV6 adapters for sale if needed). These have dyno time only. Only selling because I had to switch to ID850's to run e85. SOLD!!!!
Here's a link to Tony's build where the injectors originated for more info: https://ls1tech.com/forums/generatio...ker-ready.html
Stock LS3 fuel rail-SOLD!!!!
I will post pics as soon as I can. PM me for a faster response.
I am not positive, but I think they should be a direct replacement for LS6 injectors. I believe the LS6 uses the taller injectors with the EV1 connector. Please confirm though.
