New Pics FMS 346ci Longblock... >:)
1 Post
Here's a few more pics of the new motor..
FMS 346ci Solid Roller LS6 w/ FAST 90mm Intake & TB
More to come....
Lee
More to come....
Lee
1 Post
Originally Posted by SPANKY LS1
Very nice indeed. When will it be running? Are you going to dyno it, or will we see track numbers first?
Shawn
Shawn
The ATI damper is a 60% underdrive unit, I don't think it would run the altenator enough for a street application like the ASP does.
Lee
1 Post
Originally Posted by Jason99T/A
Good luck with your setup Lee. That looks like a killer motor.
What are you doing for a fuel system?
Jason
Jason
For the fuel system, I've completely removed the stock tank and all fuel lines from front to back. Going in the car is the following:
Custom Sheetmetal 3 Gallon Fuel Cell
Weldon EFI Fuel Pump
Aeromotive Fuel Filter
-8an Feed Line to the Fuel Rail
Speed Inc Billet Fuel Rails
FMS 42 lb Injectors
Aeromotive Fuel Pressure Regulator
-6an Return Line
That should be enough to feed the little beast hehe. I'm installing the fuel cell, Pump, Filter etc.. in the T-top holder area in the back of the car. So I spent tonite fabricating a fuel box and am enclosing the whole area with sheetmetal. I have a hinged access door on top of the box so I an easily refill the fuel cell etc. The only bad thing is I have a feeling the new fuel setup is WAY lighter than the OEM tank and crap I took out. I am going to have fab some kind of ballast box next to add a few pounds so I can hit that 3450 RW at N vs S. Also I started watching my diet again (I want to lose like 20 lbs) I already lost 6 lbs this week. I may have to go back to eating burgers and junk to help bring up my race weight LOL
Lee
