Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
454 LSX balanced rotating assembly for Tall Deck block - Eagle, Wiseco, FM SOLD
Old 11-26-2014, 10:33 PM
helicoil's Avatar
Default 454 LSX balanced rotating assembly for Tall Deck block - Eagle, Wiseco, FM SOLD
Category: Accessories
Price: $1234567890
Location (State): AL
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
454 LSX rotating assembly for LSX tall deck block, or RHS - 9.750" deck height - Save over 1200.00 dollars on this set up.
similar set up from Texas Speed:
https://www.texas-speed.com/p-1029-t...-assembly.aspx
Includes:
Eagle 4.250" 4340 steel crank with ESP armor (nitride)coating
-crank has been balanced and has had a roll pin added for the ATI balancer hub, NO BALANCER (hub only) - balancer shell must be purchased from ATI (300.00), or you can run a different set up all together not using pin
Eagle H-beam 4340 steel rods 6.460" length, ARP 2000 7/16" bolts
Wiseco custom LS7 valve pocket flat top piston, -8cc's, with GFX 1.5MM, 1.5MM, 3.0MM rings, heavy wall tool steel pins, 1.165" CD
FM 152M Competition main bearing set
FM 8-7100CH Competition rod bearing set
Serious only,
Old 12-30-2014, 06:48 PM
helicoil's Avatar
PM's returned
Old 12-30-2014, 08:57 PM
BLKLS1CAMARO's Avatar
Newbie question but you can use this on a ls1 block?
Old 02-17-2015, 09:50 PM
helicoil's Avatar
To the top
Quick Reply: 454 LSX balanced rotating assembly for Tall Deck block - Eagle, Wiseco, FM SOLD
