1980 ford fairmont 6.0 lsx 4l80
Year: 1980
Make: Ford
Model: Fairmont
Price: $7900
Mileage: 2147483647
Private or Dealer Listing: Private Listing
Location (State): KY
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Engine- 6.0 ls motor, 370 cui stock rotating assembly arp rod bolts, ls3 square port heads, milled .40, ls9 headgaskets, head studs, trick flow cam, sheetmetal valve covers, btr valve springs, dynatech 1 7/8 headers, nitrous express plate kit, 150-250. Remote bottle opener, bullet mufflers, 750 cfm holley
Trans- 4l80 with trans brake, it has the jakes full manual control black box, revmaxx 4k stall converter, tci outlaw shifter
Rear end- Foxbody 8.8, 4.10 gear, mini spool, 28 spline moser axels
Wheels/tires- Summit drag thrusts, 275 drag radial like new, wore out front runners
Body- 95% rust free, original tird brown
Front suspension- Team z ls swap k member, team z lower control arms, strange 10 way ajust. struts, caster camber plates, new disc brakes
Fuel- 15 gallon polished alum. fuel cell, 10 an push loc all the way to the front, holley blue pump, fuel regulator.
Interior- Factory bench, all stock, no cage
This is a brand new build ive just lost interest, needs headlights wired up and brake lights, needs the caster/camber set, THIS CAR IS NOT PRETTY ITS NOT NICE, its well built. Ive drove it some here around town and it runs great, shifts good, sounds awesome, no trades, I can help arrange shipping, call or text 606-305-2885
