Direct replacement 42lbs Injectors for ls1?
Not sure what HP level you will be at or what they support...
When my car was running it's best I was seeing high 60s-low 70s duty cycle. It was making an estimated 460-475 crank HP at the time I would say (dyno 390rwhp unlocked converter and closed cutouts). Trapped 95mph in the 1/8th in a 3700lb car.
I had these 42 lb injectors on my 427ci with 500 RWHP....so 41.5 pounders should be fine.
Ha, if my heads flowed over 275@.600 I would be shocked. Nearly stock just trimmed the intake valve guide boss, removed rocker boss, and sanded the ports. Exhaust has nothing but sanding rolls done to them.
Still a GM valve job, just lapped them in. 1 valve came from a different head even.
