Hood Or Bumper Doesn't Line Up Right????
Old 12-10-2014, 05:59 PM
1995_maro_z's Avatar
Default Hood Or Bumper Doesn't Line Up Right????
There is a gap between the hood and the front bumper on the passenger side front of my camaro. How could i go about finding out if it is the hood or the bumper, and why would just one side be off? Could the hood possible be bent a bit? The car was like this when i got it a couple weeks ago, so i have no clue how it got this way. Any help would be greatly appreciated. This little gap drives me crazy!
Old 12-11-2014, 02:15 AM
savage388's Avatar
Check under the hood to see if the plastic headlight braket that runs from left to right is cracked or has been glued back together, my camaro looks the same way from that bracket being busted.
Old 12-11-2014, 09:28 AM
I'll check that out when i get home tonight! Have you been able to do anything to make it line up better?
Old 12-12-2014, 01:45 AM
savage388's Avatar
Not really, the previous owner tried to glue it back together but I just had to find a used one to replace it with.
Old 12-12-2014, 12:28 PM
I'm not 100% sure that I was looking at the right thing, but nothin looked cracked, broken, or out of place. What are the chances that the hood could be bent just a tad?
Old 12-12-2014, 04:42 PM
Spartan7's Avatar
It's possible. It's hard to tell from the pics, but how is the hood alignment with the passenger fender? Also check both hood bumpstops on the passenger side and make sure they're adjusted right.
Old 12-12-2014, 05:14 PM
The gap between the hood and the fender on the passenger side is just slightly larger than it is on the drivers side, but it is definitely bigger. The bump stop on the passenger side is actually missing lol so I'm not worried about it pushing that side up.
Old 12-14-2014, 02:09 PM
savage388's Avatar
Here's what you'll be looking for, yours will probably be black, check the bottom side if the piece for cracks too.
Old 12-14-2014, 09:05 PM
SparkyJJO's Avatar
Fix your driver side foglight too while you're at it
Old 12-14-2014, 11:05 PM
savage388's Avatar
It seemed a little crooked didn't it lol
Old 12-14-2014, 11:16 PM
2001_Z28_FUN's Avatar
Hey, I just installed the VFN fiberglass 4" cowl on my 2001 Camaro and had to adjust the "Hood Levelers" they twist down and up to level out the hood as it rests on them, Maybe that could have something to do with the lift on the passenger side?
-Could be a easy fix, Goodluck !
Old 12-15-2014, 09:28 AM
Attachment 480585
Attachment 480586
Attachment 480587
Thanks a ton for the pics. I think i was looking at the core support before haha I'll look again at that area when i get home.
LOL I'll take a look at that too!
I'll look at those too, and your car looks DAMN good.
Thanks for the replies everyone! I will update after i have further inspected and played with it this afternoon!
Old 12-15-2014, 09:34 PM
Thanks man, almost lost my Car in the Divorce, had to battle that woman to keep it, she took almost everything I owned.... but no way she was taking the Camaro
Old 12-21-2014, 09:19 PM
UPDATE!!!!:
Upon closer inspection of the bar thing that supports the headlights, i have discovered some strangeness. This is the area i am referring to.
There is a bracket on each side of the car where this bar thing attaches to the rest of the car (probably to the core support, but im not sure). The bracket on the drivers side of the car (the side that isn't messed up lol) is broken (seen here)
The bracket on the passenger side (the messed up side) has a bunch of shims or spacers of some kind on it. (seen here)
Do you guys think that removing some or all of those shims or spacers will close that gap in the bumper? Here is a picture of the misalignment of the bumper with the fender on the passenger side (the messed up side)
Old 12-22-2014, 06:17 PM
savage388's Avatar
It almost looks like the car got wrecked at some point and those shims are there to help get it close to being straight. You can remove them, just remember where they go incase it doesn't help.
Old 12-22-2014, 06:41 PM
I'm probably going to play with them some tomorrow and i will update afterwards!
Old 12-23-2014, 03:20 PM
Spartan7's Avatar
That was my thought also, those ghetto fixes scream wreck. I would definitely put replacing the header panel (that big plastic part that the headlights and front bumper bolt to) at the top of the list. That will help you narrow down any more issues you might have, like a tweaked core support or damaged brackets. Try and find a decent one from the junkyard, the GM header panels are much better quality than aftermarket ones.
Old 12-23-2014, 06:30 PM
I just removed the shims and the gap between the bumper and the hood on the passenger side is A LOT smaller now. It still isnt quite perfect. I assume this is due to the drivers side bracket thing being broken. It is dark out right now so i can't get any pictures right now, but i will post some up tomorrow.
Old 12-26-2014, 10:42 AM
s-350's Avatar
definitely looks like a light front end impact! look on here or ebay for a new header panel will probably get you straightened out
Old 12-27-2014, 09:58 AM
I finally was able to get some updated pictures since i took the shims out. I wouldnt say it is perfect now, but it is certainly a ton better, and honestly its good enough for now for me. You can definitely tell that it is better, especially in the second picture. (It was also warm enough to take the ttops out the day after christmas in indiana! )
Quick Reply: Hood Or Bumper Doesn't Line Up Right????
