twist tite hose?
twist tite hose?
Working on plumbing a stand alone fuel cell for spray. Was planning on running all stainless line with an fittings. I saw the twist tite hose and fitttings from summit and they area lot cheaper than stanless( hose and fittings). Are these any good? Will they pass tech? Any input is appreciated. also has anyone used them for trans cooler lines
Do not use push-lock type hose/fitting on transmission cooler lines. They will come off. The transmission fluid heats the hose and the pressure pushes the hose off the fittings. I've witnessed this happen I don't know how many times, resulting in wrecked cars and several fires.
Strange! Both the hose and fittings are rated for oil use and 250# pressure. I've had push-lok's and #10 hose from my GN V6 engine oil pump thru a dual spin-on remote filter (and back) since 2001 and never had any problems with it. That's 80# cold pressure and 220° hot temp...
Thanks for the input, More I think about it I may just have some hydrolic lines made up. Would cost maybey 20 bux over stainless but it would take heat and be crimped
