NEED HELP 4l80e guru's
i have a 4l80e full manual with jakes trans brake. Trans brake isnt hooked up. i can go thru all gears except 1st. car is on jack stands when i shift it to 1st tires quit spinning even if i give it gas? Any ideas? 3500 triple disc lock up converter?
Hey jake,i put 12 volts to red/pink wire and ground the yellow. No change. Car stays run and revs but rear wheels wont move.should i be able to here selinod in trans click? I think it mite be stuck? I left u a voice mail also earlier.On that plug there is yellow,red and brown.
That harness isn't going to work to make it full manual. Our D1 transbrake works great when setup in combination with our manual control box. Without the manual control box, it operates as stock, and must use a controller/PCM.
If you are using an LS style PCM you can use it to control the trans and HPTuners or EFI Live to tune it. If you need a standalone controller, we sell the US Shift. It's $550.
