4l60e questions (99 silverado 4wd)
Old 12-15-2014, 12:20 AM
GiggleJuiced_SS's Avatar
Default 4l60e questions (99 silverado 4wd)
So I'm new to the 4l60e transmissions. Until now I've had t56 or th350/400s. So I'm looking to do some bolt ons to the truck (cai, full exhaust, tune, stall, shift kit, maybe a small cam). This is my daily driver and I will still tow with it. Anyway what shift kit are you guys going with? I seen transgo is popular. Also what stall speed would work well. Can I order a converter that would fit a 98-02 fbody? Right now the truck is bone stock (down to the air filter lol) 97k miles.
Old 12-17-2014, 09:52 PM
Bump.
Old 12-17-2014, 10:42 PM
Moderator
mrvedit's Avatar
The only shift kit detailed here is the Transgo HD2.
The Sonnax billet 4th gear servo is useful for towing applications; their billet 2nd gear servo is probably overkill for your needs, but is designed to work well with the 4th gear servo.
Your post is confusing - you first mention a truck and then an F-body. And your signature is definitely not stock.
For a converter recommendation we need your engine specs, rear end ratio, vehicle weight and more.
The converter for all LSx engines are interchangeable.
Old 12-18-2014, 06:46 AM
Sorry when I mentioned fbody converters I meant because they both had the 4l60e transmissions. Most sites don't list too many options if you search under a truck. So that's why I wondered if ordering while searchin under a car would make a difference. Like revmax converters I don't think they list for a truck.
Truck weight - 4400lbs
3.73 gears
33" tire
motor is stock.
Old 12-18-2014, 10:21 AM
Moderator
mrvedit's Avatar
Understood.
Other than 2WD versus 4WD, all 4L60E/4L65E/4L70E behind LS engines, truck or car, are mechanically compatible and their converters interchangeable.
I don't want to suggest a converter for your truck, but either call one of the sponsors, or perhaps they or other expert will give you suggestions here. I'll guess (just a guess) something in the 2800 stall range. Skip the under $450 converters as they have flimsy lockup clutches.
Old 12-18-2014, 11:08 AM
I'm just wondering if I'd be better off going to a 4l80e and sale this one while it still works 100 % lol.
Quick Reply: 4l60e questions (99 silverado 4wd)
