Where to get brand new stock injectors?
Kind of a dumb question, as I could probably just head on down to AutoZone and have them order me a set. But where can I order stock injectors for my 2002 TA WS6? Looking to refresh a lot of things on the car, figured the injectors are probably clogged with all the crappy gas in Iowa. Was thinking maybe I could go to higher rated injectors, since I will be doing Heads/Cam eventually, and could just have Frost mail tune for the larger injectors (I will be sending him my PCM in the spring to tune for my full exhaust/intake swap, and want to have everything done in one go). Is it even possible for him to mail-tune for larger injectors safely?
I'm not looking to spend $500 on 42lb injectors, but I also don't want to get cheapo $25 AutoZone specials.
Found these on fleabay,
http://www.ebay.com/itm/8-Genuine-Bo...-/251754454864
They seem too cheap to be good, but if they are better than my stock 28lb worn-out injectors, seems like a win win.
Any advice on what to do would be appreciated. Heads/Cam wont be for a few years at least, so even 28lb replacements is fine
why not just have your injectors sonic cleaned? It can be done locally and they'll be good as new.
I wouldnt touch ebay specials injectors. If anything buy a set of low mile ls3 take offs here in the classifieds. they are rated at 42lbs but will need height adapters to fit ls1 rails. but they can be mail tuned very easily
