Crane Cams 232/236 .600 cam
Category: Engine - Power Adders
Price: $325
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NJ
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
I won this cam in a contest, but sadly after some research it wont work right for my application.
It was used for 4 dyno pulls in a 408 stroker, to do a cam comparison test.
It made 580hp/565tq (dyno sheet attached) according to the company, Onthedyno.com. It looks brand new. I'm a reputable seller on CTSVowners.com forum, TurboBuicks.com, and eBay of course.
Here are the specs and link from Summit.
Brand:Crane Cams
Manufacturer's Part Number:1449331
Part Type:Camshafts
Product Line:Crane Hydraulic Roller Camshafts
Summit Racing Part Number: CRN-1449331
UPC:021174033304
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:2,900-6,500
Intake Duration at 050 inch Lift:232
Exhaust Duration at 050 inch Lift:236
Duration at 050 inch Lift:232 int./236 exh.
Advertised Intake Duration:294
Advertised Exhaust Duration:298
Advertised Duration:294 int./298 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.600 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.600 in.
Valve Lift with Factory Rocker Arm Ratio:0.600 int./0.600 exh.
Lobe Separation (degrees):114
Camshaft Gear Attachment:3-bolt
Computer-Controlled Compatible:Yes
Grind Number:HR-232/353-2S1-14
Valve Springs Required:Yes
Camshaft Manufacturers Description:Weekend driver, for modified 5.7L thru 6.0L, choppy idle, upgraded cylinder heads and valvetrain required, headers and aft cat exhaust required, 11.5+ compression ratio advised, low ratio gearing required, auto trans w/3600- 4000 stall converter, computer tuning required.
Notes:Headers, heads, upgraded valvetrain, exhaust, 11.5 and up compression, low gearing, and stall converter from 3600 to 4000 are recommended. Computer tuning required.
http://www.summitracing.com/parts/crn-1449331
Asking $325 OBO plus 3% paypal and the ride. Thank you!
No reasonable offer refused.
