Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
1998 Camaro - Turn Key NASA American Iron Race Car
Old 12-23-2014, 06:33 AM
athornt2's Avatar
Default 1998 Camaro - Turn Key NASA American Iron Race Car
Year: 1998
Make: Chevrolet
Model: Camaro
Price: $11500
Mileage: 1
Private or Dealer Listing: Private Listing
Location (State): GA
Color: Green
Transmission: Manual
Drivetrain: Rear Wheel Drive
1998 Camaro - Turn Key NASA American Iron Race Car $11,500
Engine/Cooling
-5.3L LM4 with 30k miles - Makes great oil pressure. 60 PSI at race temp
-ASA Cam
-LS6 Valve springs
-Shaner Ported throttle body
-BBK Longtube Headers
-BBK 2.5" Y-pipe into 3" Merge
-Dynomax Bullet Muffler Dumped/ Also have Borla XR-1
-Improved Engineering oil pan Baffle
-340 rwhp/340 rwtq
-Tuned by MTI Racing
-3 qt Accusump
-Earl's Oil Cooler with Carbon fiber shroud
-C&R Radiator
-Core support eliminated allowing the radiator to be angled forward - Vented out of the hood
-Custom tubular front bumper incorporating front breather setup
-Water temps run 180 during hot summer months
-Oil temps run 255 in hot summer months
-Canton Racing Remote Oil filter adapter
-Comp Cams 15w-50 Oil
Transmission
-Fresh Super T-10 w/ 2.43 first gear ratio
-Hurst Competition Plus Shifter
-New Transmission Pump & Cooler
-7 1/4" V-Drive Quarter Master Clutch
-Quarter Master Aluminum Bellhousing
-Quarter Master Reverse mount starter
-Custom drive shaft from the Driveshaft Shop
Rear End
-10 Bolt
-Detroit Tru Track Differential
-3.23 gear
-Aluminim T/A Girdle
Suspension
-Front & Rear Coilovers
-SN Series Bilstien Shocks (freshly built)
-Hypercoil Springs
-Rear shocks mounted with heims/clevis and have been tied into the roll cage
-LG Lower A-Arms
-93 Boxed Upper Control Arms with Global West Del-A-Lum Bushings
-Strano Hollow 35mm front sway bar
-Stock rear sway bar; Also have hellwig adjustable rear bar
-UMI Boxed subframe connectors
-Adjustable rear lower control arms w/ heims
-Unbalanced Engineering lowering Panhard Bar brackets
-3 Link Rear - tied into roll cage
-Adjustable UMI Panhard Bar
Brakes
- 4 Piston Brembo Calipers
-Custom Brake brackets made by MTI Machine to allow 17" wheels
-2005 Subaru STI Brake rotors
-Custom fabricated brake cooling duct
-Raybestos ST47 Front Pads
-Stock Rear calipers
-Hawk HT10 Rear pads
-Wilwood Brake Bias adjuster
-ABS deleted
Safety/Interior
-6 Point Roll Cage - NASA approved
-Driver side Nascar door bars
-Schroth Hans 6pt Harnesses
-Floor mounted fire extinguisher
-Sparco Pro ADV Seat
-Carbon Fiber Dash from RCR Nationwide Team
-Autometer Tach, Oil Pressure, Oil Temp, Water Temp Gauges
-Midwest Chassis drive shaft safety loop
Aero
-Custom front Splitter mounted 3.5" off the ground
-COT Carbon Wing
-11 lb Carbon Fiber Hood
-Radiator shroud exit through hood
Extras
-1 extra set of OEM 17x9 ZR1s w/ Toyo RA1 tires
-BCM
-Upper Control Arms
-Lower A-Arms
-Shock Clevises
-160 Thermostat
-Throttle Body
-2 Rear brake calipers
-1 Rear brake rotor
-2 Front hubs
-10 Bolt Rear end housing
-Axle
-Auburn Differential
-GM Header Gaskets
-1 sets of LS1 heads
http://classifieds.racerconnect.com/details.php?id=471
Old 01-06-2015, 06:18 AM
athornt2's Avatar
I am open to offers. The car is still available.
Old 01-14-2015, 09:06 AM
athornt2's Avatar
Price lowered to $12,000. Don't hesitate to make an offer. I need this gone.
Old 01-15-2015, 07:59 AM
athornt2's Avatar
Lowering again. $11,500. I need the funds for another project.
Quick Reply: 1998 Camaro - Turn Key NASA American Iron Race Car
