How much slop in timing chain is acceptable??
Old 05-27-2004, 08:24 PM
1fastWS6's Avatar
Default How much slop in timing chain is acceptable??
Pulled my timing cover off tonite for my cam swap and noticed the timing chain seems loose to me. It has 3/8" - 1/2" of slack on both sides. This is a Katech/JWIS chain on the stock crank/cam gears and only has about 6-7k miles on it. Engine has 19k on it total. I don't recall if it was this loose or not when I put it in last year but I wouldn't think this stout chain would stretch much in that few miles. No abnormal looking wear on the chain or gears.
I'm pretty sure it's ok, but can anyone give me some piece of mind here?
Craig
Old 05-27-2004, 08:37 PM
Speedy's Avatar
1/4" in of slack is the most it should have. Anything more replace it. Pretty odd you have that much play at such low mileage.
Old 05-27-2004, 09:37 PM
01_SuperSlow's Avatar
When I put my JWIS in, it had the same slack as the stock chain did. I wouldn't worry about it if I were you.
Old 05-28-2004, 11:04 AM
1fastWS6's Avatar
1 vote yes
1 vote no
anyone else??
Old 05-28-2004, 11:07 AM
PHIL H's Avatar
Dont worry about it..For some reason they are stupid sloppy and thats just how it is..I changed chains on mine and the new replacement was as bad as the used one.. I am used to the SBC BBC chains that were actually tight so this was new to me also.
Phil
Old 05-28-2004, 12:04 PM
Colonel's Avatar
Another vote to not worry about it. They're sloppy loose even when brand new.
Old 05-28-2004, 01:25 PM
ChevyNo1's Avatar
In a phone call yesterday with another guy on ls1tech ( sr71 ) he also said they have a lot of slop in them . . .
Old 05-28-2004, 01:29 PM
1fastWS6's Avatar
Ok, thanks for the advice guys. I called Thunder Racing too and they also said they're sloppy.
Quick Reply: How much slop in timing chain is acceptable??
