98-02 Camaro conversion
Hello I was wandering can someone help me out to see if I'm missing something my hood n front bumper is not line in up
Do you have any pics of where the nose attaches to the core support from the inside of the engine compartment? Also, are your headlights just sitting there loose or are they bolted it? They look wierd to me....
looks like you need to get fender to hood gaps adjusted a bit better. even side to side and front to back same spacing. bumper cover looks like needs lifted up in middle. headlights on insides adjusted back a little. all your parts aftermarket or some GM? sometimes if you use aftermarket you have to compromise some where. I worked in body shop 8 years all normal for aftermarket stuff. mainly hood side gaps/ lift bumper in middle get you happier I think.
