Bigger injectors
Bigger injectors
Hey guys, I'm switching up to 32LBS an hour injectors on a 2002 T/A with the following power mods
218/224 .525/.525 112 Cam
FAST 90 MM intake
SLP lid
Grotty Longtubes
Magnaflow Catback
The car has been tuned already by a pro but I want to change the flow rate for the injectors with LS1 edit and am not sure how to calculate it out. Any help would be appreciated
FAST 90 MM intake
SLP lid
Grotty Longtubes
Magnaflow Catback
well you need to see what the injectors flow at the same pressure your oem injectors do. Then you need to see exactly what percentage more they flow. The modify the AFR table by that difference.
Dave
Dave
