01 ta ms3 cam,bolt ons,nitrous, fti th400 w/ fti 4000 stall,darkstars mt dr's,issues*
Year: 2001
Make: Pontiac
Model: Trans Am
Price: $6000
Mileage: 107500
Private or Dealer Listing: Private Listing
Location (State): MO
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
SLP LID
SLP 85MM MAF
SMOOTH BELLOWS
1 7/8" LONGTUBES
brand new 3" TSP ORY INTO 3" DYNOMAX BULLET
MS3 CAM ON A 112+1
HARDENED 7.400 PUSHRODS
MELLING HIGH PRESSURE
PRC .650 SPRINGS
N-MOTION TIMING CHAIN
LS6 INTAKE(obvious by year!)
RACETRONIX 255 LPH E85 COMPATIBLE PUMP+HOTWIRE KIT(10 MILES IF THAT ON THE TWO)
the cam and associated parts got 8k miles on em. THE CAR IS STREET TUNED BY JUSTUNE, ONE OF THE BEST TUNERS IN THE MIDWEST AND HAS GREAT MANNERS. I DONT HAVE TIMES OR DYNO NUMBERS. BUT EVERYONE SHOULD KNOW WHAT THOSE SHOULD BE AND IF NOT, DO A SEARCH.
TRANSMISSION- ALL PARTS GOT 300 MILES AND I GOT RECIEPTS
FTI LEVEL 3 FMVB TH400 GOOD TO 800HP
FTI HARD HIT 4000 STALL
TCI SFI 29.1 FLEXPLATE
DEEP PAN W/COOLING FINS
ARP FLYWHEEL BOLTS
BIG PLATE STYLE COOLER
POLY MOUNT
BMR ADJ TORQUE ARM TRANNY MOUNT (RED)
3' STEEL DRIVESHAFT WITH 1340 YOKES.
FACTORY SHIFTER
AUTO METER TEMP GAUGE
SUSPENSION- ALL PARTS GOT LIKE 300 MILES ALSO NO RECIEPTS.
LOWERED (CUT FACTORY SPRINGS)
BMR LCA'S
BMR ADJ LCA BRACKETS
BMR ADJ PANHARD BAR
SLP STRUT TOWER BRACE
REMOVED FRONT SWAY BAR
TIRES & WHEELS- ALSO NEW WITH 300 MILES AND CAN GET RECIEPTS!
RACESTAR DARKSTAR'S DIRECT DRILL 15X10 15X3.75
MICKEY THOMPSON ET STREETS 295/55
165/80 FRONTS
MISC PARTS AND OTHER STUFF
SLOTTED AND DRILLED ROTORS
DUAL A PILLAR POD W/ TRANNY TEMP AND NARROW BAND AF GAUGE
ALL FOSGATE SPEAKERS
2-12" SUBS
1000 WATT AMP
LO-JACK EQUIPPED(CERTAIN STATES GIVE INSURANCE CUTS FOR THIS)
35% TINT
VHT'D SIDE MARKERS
WIRE TUCK MOD
REMOVED SIDE MOLDING
NEW WITH RECEIPTS---RADIATOR,WATER PUMP,THERMOSTAT,RAD CAP AND HOSES.
*******NOT INCLUDED BUT WILL SELL WITH THE CAR FOR EXTRA MONEY- NOT 1 BOTTLE RAN THROUGH NOIDS!! PRETTY MUCH BRAND NEW.********
N.O.S. BRAND WET NOZZLE KIT-SOLENOIDS GOOD TO 150HP **THEY ARE THE OLD STYLE NOIDS I BOUGHT OF EBAY LAST SUMMER FROM OLD STOCK, I GOT PICS OF IT BRAND NEW IN PACKAGING WITH THE RECIEPT TO PROVE NEW.****
NITROUS OUTLET PURGE KIT
LNC-2000 TIMING CONTROLLER AND 2 STEP
MSD DIGITAL WINDOW SWITCH
JETTING FROM 50-150
HOMEMADE SWITCH PANEL W/LED LIGHTS FOR NOIDS,PURGE BUTTON AND TWO SWITCHES(MAIN ARM AND HEATER SWITCH)
JUST MISSING THE HEATER
FULL BOTTLE OF THE JUICE
THE BAD ABOUT CAR- AIR IS GETTING IN THE COOLING SYSTEM VIA BLOWN HEAD GASKET OR A CRACKED BLOCK(IM GUESSING) AND PUSHING COOLANT OUT THE OVERFLOW. DOESN'T OVERHEAT JUST LOOSING COOLANT. AND SOMEHOW THE ******* FRONT SEAL ON TRANSMISSION GOT DAMAGED BY A SHIRT IN THE ROAD THAT GOT SUCKED UP AROUND THE TORQUE CONVERTER SNOUT AND IN BETWEEN THE FLYWHEEL. PART OF IT GOT PULLED OUT WHEN I WAS DIGGING IT OUT.( FREAK THING THAT HAPPENED,ONLY COULD HAPPEN TO ME. FML!!) I GOT THE NEW SEAL JUST HAVENT PUT IT IN. LEAKS A BIT OF TRANNY FLUID, NOTHING MAJOR THOUGH. THE BODY IS IN FAIR SHAPE WITH SOME SCRATCHES AND A DOOR DING OR TWO AND SOME ROCK CHIPS ON NOSE OF CAR AND SOME DINGS IN HOOD. SOUNDS WORSE THAN IT IS JUST BEING UPFRONT SO NO SURPRISES. A SMALL 1" TEAR ON TOP OF BACK SEAT. WINDOW MOTORS NEED REPLACED AND NEEDS A NEW HEADLIGHT MOTOR FOR DRIVER HEADLIGHT. MISSING TWO AC VENTS(HAD GAUGES THERE PREVIOUSLY) A FEW STAINS ON CARPET.
THE LEATHER INTERIOR IS IN VERY GOOD SHAPE OTHER THAN A 1" TEAR ON TOP OF BACK SEAT. DASH IS NOT CRACKED AND DOOR PANELS ARE GOOD EXCEPT PASSENGER HAS THE USUAL CUT ON TOP. IT CLEANS UP GOOD AND LOOKS GOOD.
$$$$$$$$$$ I DONT WANT TO TRADE, PART IT OUT, SWAP RIMS OR ANYTHING SO DONT ASK. CASH ONLY $$$$$$$$$$$ I COULD PART IT OUT AND GET WAY MORE BUT I DONT HAVE TIME FOR THAT. IF YOUR LOOKING FOR A PROJECT THIS IS IT. IT DOES RUN AND DRIVE.
THE WAY I SEE IT IT BREAKS DOWN LIKE THIS:
ALL MOTOR AND SUSPENSION PARTS: $1200 IF PARTED WAY MORE.
TRANSMISSION STALL AND SWAP PARTS: $3000. I PAYED ALMOST 4K AFTER TAX SHIPPING ETC.(300 MILES!!)
WHEELS AND TIRES:$1200 PAYED $1700
AFTER SHIPPING TAX AND MOUNTING(300 MILES!!)
BODY AND INTERIOR:$2000
THATS $7400 SO THE $6000 IM ASKING IS FAIR. IF YOU WANT THE NITROUS SETUP PRICE IS $6700 FIRM. AND IF ITS JUST A HEAD GASKET THATS EVEN BETTER!! IM JUST OVERWHELMED WITH WORK,4 KIDS AND OTHER LIFE DEALINGS RITE NOW TO MESS WITH IT AND AM OVER IT.
im in kansas city mo and can be texted at 816-772-9066 for questions. please guys only serious buyers. thanks
