Rear End Gearing. NEED A CHANGE!
Old 01-15-2015, 04:38 PM
DNTBJELOUS's Avatar
Default Rear End Gearing. NEED A CHANGE!
Currently my car is about 425 RWHP & 375-380 ft/lbs of torque & it is a 6 Speed. Planning to put the car on a 26 inch slick this coming season. My rear end gear is the only other thing hurting me in this equation though, at least this is what I believe. The rear end is a Strange S60 with a 3.54 or 3.55 (correct me if I am wrong). I believe this is way too small of a gear for the rear end with the 6 speed set up that I am running. Any opinions?
Old 01-15-2015, 04:49 PM
HCI2000SS's Avatar
I run a 4.10 gear on a 6-speed with about the same power as you and love it!
Old 01-15-2015, 04:55 PM
guppymech's Avatar
Yea, you definitely need some 4.10s or the same series carrier will take 4.30s. Saw your tire thread, with the M6, bias plys for sure.
Old 01-15-2015, 05:00 PM
DNTBJELOUS's Avatar
I was leaning towards the 4.10 rear end gear set up as I have a daily driver if this becomes not streetable. I don't drive it that far but I do enjoy taking it on cruises every so often & not just taking it to the track.
Old 01-15-2015, 05:15 PM
FirstYrLS1Z's Avatar
4.10s' with a 6 speed is a very popular combination for a daily driver.
Old 01-15-2015, 06:49 PM
DNTBJELOUS's Avatar
Highway usage it's decent?
Old 01-15-2015, 07:11 PM
1600rpm at 60mph makes A4s' jealous !
Old 01-15-2015, 07:22 PM
DNTBJELOUS's Avatar
That's true haha well 4.10 it is then! Reasonable price for labor to install the gear?
Old 01-17-2015, 01:27 AM
Fry_'s Avatar
This should help you see the effects of gear and tire changes.
Gear Ratio Calculator
Quick Reply: Rear End Gearing. NEED A CHANGE!
