AWD 4l80e to 2wd
Old 01-16-2015, 03:13 PM
Rootbeer02's Avatar
Default AWD 4l80e to 2wd
have 2 AWD trans, vehicle that its going into is 2wd already.
so swapping from AWD to 2WD needed parts...
rear planetary with reluctor
2WD output shaft
2WD tail shaft housing
anything im missing? don't waste time giving me the lecture about selling them and buying 2WD. they are coming apart for a full rebuild and upgraded shafts anyway.
Old 01-17-2015, 06:34 PM
tgui's Avatar
2WD output shaft
What year trans? I just converted my 2wd 4l80 to 4wd and have all needed if you want to pay for shipping and send some beer from your part of the world.
Old 01-18-2015, 01:04 PM
Rootbeer02's Avatar
I have an 04 and an 05. ill pm you
Old 01-20-2015, 07:07 PM
LS1Tech Sponsor
performabuilt's Avatar
Do bear in mind when converter to a 2wd from a 4x4 you will need to open the lube returns at rear of case . They are plugged in the 4x4 version.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 01-21-2015, 08:22 AM
tgui's Avatar
On the flip side I'm going 2wd to 4wd. How do I plug the lube return?
Old 01-21-2015, 11:56 AM
5.0 LsX's Avatar
I would be interested in getting all of the necessary parts to convert a 2wd to a 4wd, if someone is willing to let them go, please pm
Old 01-22-2015, 11:22 AM
tgui's Avatar
Orifice plug # is 8675516 for 2wd. Plug # 9427692 for 4wd. The first has a hole to pass ATF to the tail housing on the 2wd transmissions.
Old 01-12-2016, 07:25 AM
schwoch1's Avatar
Default 4wd to 2wd extension housing conversion
HI All
installing a 4wd 4l80e into a 2wd 1970 c10 we needed some type of tail housing to convert the 4wd to 2wd. searched the internet for a housing, found nothing. I was at the machine shop down the street and saw something similar he was building for a truck PTO. told him what we needed and he built us one. bolts right on to the transmission.looks just like a bolt on yoke. but all one unit.saved the trouble and expense of pulling apart the trans to replace the tail shaft.
Mike
Old 01-12-2016, 07:31 AM
bbond105's Avatar
That is a very nice looking part. Is he looking to market the adaptor and if so how much will he need to sell them for?
Old 01-12-2016, 07:43 AM
schwoch1's Avatar
Default tail housing
I mentioned to him there may be some interest in them, but was not sure. he has all the programs to make them. I supplied the yoke. he supplied the bearing,snap rings and aluminum. the yoke was $50.00 and he charged us $400.00 to make and assemble it. $450.00 I thought that was fair.
Schwoch1
Old 01-12-2016, 07:51 AM
bbond105's Avatar
That’s not a bad price. I bet people who don’t feel comfortable tearing a trans apart to replace the tail shaft would grab this bolt it on and be on their merry way. I have a 4L 80E from a 4WD and am looking to swap it in to my 2002 Trans Am, but my trans needs to be rebuilt. So I will just replace the shaft and housing. I can see a real big market for these.
Old 01-13-2016, 08:30 PM
clinebarger's Avatar
Originally Posted by schwoch1
HI All
Mike
How is the bushing getting Lube?
Bbond105....
You don't need the Output Carrier, Sonnax makes a OSS Reluctor wheel to press on a 4wd Carrier, part# 34880-01, Sells for around $25.
2wd Output shaft
2wd Orifice cup plug
extension housing
OSS sensor
Old 01-13-2016, 10:27 PM
schwoch1's Avatar
Hi All
No bushing in the housing it is a sealed bearing. the unit is all pressed fit together and held in place with snap rings.
schwoch1
Old 01-14-2016, 06:11 AM
bbond105's Avatar
Thanks clinebarger I did not know that the 4WD Output Carrier did not have an OSS reluctor wheel on it. Where does the 2wd orifice cup plug go? I have only built one 4L80E and that was a long time ago.
Old 01-14-2016, 08:19 PM
Yep, No OSS reluctor on 4wd output carriers...
2wd Orifice Cup Plug with seal....Lubes the extension housing bushing, A new one will come in the "Paper & Rubber" kit...
4wd Cup Plug with no seal, To remove....I find it easiest to drill a small hole in the cup plug & use a small Dent Puller to extract it.
performabuilt mentioned plugs in the ATF return holes in the rear of the case on 4wd models, I have never ran across this before? Not that I convert 4wd 4L80E's to 2wd's everyday but have done quite a few & very observant when converting anything. The above pic of a '04 4wd version has no plugs?, I have a '99 4wd core at work, I will check that one. Don't have any '92-'96 4wd cores to check.....
Old 01-15-2016, 05:59 AM
bbond105's Avatar
Thanks for the info.
Old 06-28-2016, 08:20 PM
john123a81's Avatar
Default 2wd
HI All
Mike
I know this thread is old however has the 2wd conversion ever hit the aftermarket world . That part looks so simple to install
Old 02-24-2020, 12:07 PM
indyjps's Avatar
Bumping this up for any additional info on 4wd to 2wd tailhousing using the 4wd output shaft.
IM'd schwosh1, but he hasnt been on since mar 2019.
Old 02-25-2020, 11:55 PM
brandon6.0's Avatar
Is there any side effect to running a 2wd case lube plug on a 4x4 swap over?? I have one im converting for a customer. Also can the rear speed sensor relucter ring be pressed off. I know its not needed in a 4x4 setup. Maybe use a freeze plug to plug speed sensor hole??? Freeeze plug for rear lube hole??
Old 02-26-2020, 12:17 AM
vorteciroc's Avatar
Received 1,204 Likes on 844 Posts
You definitely do not want to use the 2 wheel drive case orifice that was for bringing lube oil to the tail housing bushing. (Passage shown on right side of housing).
As long as GM has not discontinued the original parts...
There is a part number for a solid plug to replace the orifice as well as an output-shaft speed sensor/ VSS dummy plug.
and
Both a freeze-plug or after-market bolt in plug are also available.
Yes the reluctor wheel can be removed if you want to.
I actually hoard those reluctor wheels ever since Sonnax stopped producing an after-market replacement.
Quick Reply: AWD 4l80e to 2wd
