lt1 camaro headlight panel replacement.
Old 01-17-2015, 05:22 PM
savage388's Avatar
Default lt1 camaro headlight panel replacement.
I'm trying to replace my smashed up headlight bracket without removing the whole bumper cover, I got the old one out in pieces but the new one won't fit. Figured if ask before I have to spend time taking it off then having to re align it when I put it back on.
Old 01-17-2015, 09:00 PM
scj
scj's Avatar
You'll have to remove the bumper cover. You're over complicating the job by not just doing so. Remove bumper cover. Install header. Reinstall bumper.
Old 01-17-2015, 10:30 PM
savage388's Avatar
I guess I'll have to tackle the hack job done on that too at the same time then, I really didn't want to have to deal with that just yet.
Old 01-18-2015, 05:12 PM
savage388's Avatar
Is there anywhere online I could find parts for the front bumper? While taking it off I found a bunch of brackets and bolts missing including the plastic honeycomb thing.
Old 01-18-2015, 10:05 PM
Spartan7's Avatar
Head to the junkyard and strip off whatever you need, I always see tons of LT1 Camaros. Then you'll be able to see what exactly you're missing and how it all goes together.
Old 01-18-2015, 10:33 PM
savage388's Avatar
There's none around, I've been making calls forever trying to find one for parts. Is there a good diagram around showing everything? I might be able to fab something up.
Old 01-19-2015, 11:58 AM
Spartan7's Avatar
Kind of blurry, but hopefully this will help. You can post up some pics of your front end for help with identifying missing parts, there are quite a few of us who have torn down the front end and will be able to tell.
Old 01-21-2015, 11:00 PM
scj
scj's Avatar
^^ this diagram doesn't even have the headlight panel on it.
Old 01-21-2015, 11:03 PM
Spartan7's Avatar
He was asking about front end components like the crash bar, he didn't specify what he needed. The header panel is on a different drawing.
Old 01-22-2015, 01:45 AM
savage388's Avatar
I haven't been able to get over there to work on it but I managed to make one of the brackets I needed, there's still two small ones I've never seen before that attach to the core support and headlight panel I believe. I'll post some pics up of what I'm missing when I can get over there.
Old 01-23-2015, 03:55 PM
savage388's Avatar
I need to know what bracket attaches to the bolt hole in the core support at each side and where it goes to, here's a picture of the hole.
I'd also like to find out what kind of bolt goes under each headlight through the headlight panel and bumper.
Old 01-25-2015, 01:12 PM
Spartan7's Avatar
93-97 Camaros don't use those. Those are for Firebirds, it's where the headlights bolt to.
Old 01-25-2015, 05:48 PM
savage388's Avatar
Okay thanks then it's all back together right then.
Quick Reply: lt1 camaro headlight panel replacement.
