roller rocker install problem
I have all of the new rockers on theyre just fingertightened and I was beginning to torque them down and at first I set the torque wrench to 22ft/lbs right where theyre supose to be torqued at and the valve spring just keeps compressing and compressing and I cant get the poly lock to torque down to 22 ft/lbs, the spring was almost fully compressed before i decided to stop. so i set the torque at 12 ft/lbs and I try a few different valve this time and the same thing happens I cant even get 12 ft/lbs. Ive tested the torque wrench a few times and that seems to be working perfect. what am i doing wrong?
roller rockers
You are trying to torque on the top of the cam lope, you need to
rotate the engine so that you are on the low or bottom of the
side of the the cam lope. hope this helps
www.ls1howto.com look under yella terra rocker install for f-body's. I used this as a guide to install my Harland Sharps to find out how to set proper preload.
pending your cam postion some of them will compress the springs almost fully, if you installed all the parts you are probably ok, check ls1howto though as well.
