LOWEST cost, pre-made, EGR block off plates?
I FINALLY want to dump my EGR system, and I have NO tools/facilities to make my own out of plate steel/alloy/etc.
Who makes the least expensive (like NOT the Hawks Third Gen high buck ones) pre-made versions of these, and do they come with gaskets or not??
I cannot find this info with the search.
Thanks in advance.
Thanks in advance.
For the egr on the headers i cut the ends off the egr pipes also, and just welded the center. Used the stock bolts and i did it when i got headers so my header gaskets came with gaskets for the egr too so i used them. Dosent look the best but it works. Ebay also has them in aluminum for under $20 pretty sure sponsors on here also sell them
Thanks, but I wanted to keep all of the pipes/equipment intact just in case I ever have to put it back on for inspection, sale to someone who wants a 50 state, emissions legal car, etc.
If you cant find what your looking for though send me a PM. I forgot to order block off plates with my headers but I have some 1/8" inch stainless steel so I was just going to make my own. If you can wait for 3-4 weeks until it warms up enough to get back to working in the garage I would be happy to make you set. I'm sure it would only cost a few bucks to have my wife drop them in the mail when she goes to grand forks ND around the end of march.
If you want to keep everything in place for emissions then why not slip a thin pice os steel in between the pipe flange and the header so everything looks stocks and you can just tune the egr out?
