dual or single fuel pump opinions please
car is 92 Camaro, LS conversion (no its not like most 3rd gens. still looks new inside and out. I bought it new). it has been converted to LS since 2008. just now completed building a single turbo kit (turbonetics 78mm). I have the plastic fuel tank from the donor car that I can use if I need to. should I run dual fuel pumps or is there a single in-tank I can run that will support 700 or so rwhp? pump gas only, no meth.
Most pump manufacturers state what their fuel pumps will do HP wise. There are a ton of options these days but from the sounds of it you want something nice to drive as well as great performance. I would look at dual in tank set ups for quiet operation. While am here, does your 9" howl at all? Thanks
I been looking at the dual pumps from lonnies and squash. ill probably go with one of them or make my own. and yes my 9" whines a little but not bad at all. I got it from BMR. I also have their torque arm, trans crossmember, k-member and front control arms. I need to post some pics of my car. its not like most 3rd gens u see everyday
