Racetronix 340 F body specific pump vs stock
Well, I won't agree with their customer service but test results were better than I expected. Today I replaced a 1999 TA fuel pump and installed a hot wire kit. The car is a heads cam setup and with stock injectors in place I was seeing 130% at WOT. We changed only the fuel pump and added the hot wire kit. Data logging then showed 104% at WOT. I know this means we still need bigger injectors but the pump and HWK definitely helped.
