What size injectors/fuel pump?
I'm building a 408 with ls3 heads. It's 12.5:1 compression. I'm assuming it should end up somewhere in the 450-500 rwhp range. I want to run E85 just to be on the safe side with the higher compression. Later on it will see any where from a 100-300 shot of nitrous. (Will have a stand alone system)
My thoughts are to run 60lb injectors with one walbro 450 e85 pump. Planning to keep the stock fuel lines and ls3 fuel rails. Will this be enough?
