Pulling Dent from rocker (pic)
Old 02-09-2015, 07:23 PM
LuckShot's Avatar
Default Pulling Dent from rocker (pic)
My buddies got a 4th gen camaro. He bought it with the dent in rocker panel, previous owner took it over a curb in his driveway.
I used to work as a detailer for a body shop out of high school and remember the techs using stud welder and slide hammer to pull **** like this out. Is there another way we can pull this off without a shelling out over $200 for a stud gun?
Attached Thumbnails Pulling Dent from rocker (pic)-dent1.jpg   Pulling Dent from rocker (pic)-dent2.jpg
Old 02-09-2015, 07:34 PM
JOHNNY59's Avatar
if you have a welder you could weld some studs on and use a slide hammer.
Old 02-09-2015, 08:20 PM
Nickelndime's Avatar
As said above studs, or weld a metal tab following the deepest part of the crease, both of which will need a slide hammer to pull the dent out. Then there's the less preferred old school way with screws which leave holes to deal with.
Old 02-09-2015, 08:58 PM
LuckShot's Avatar
Alright, thanks for the help.
Quick Reply: Pulling Dent from rocker (pic)
