which filter ...40 micron or 10?
Old 02-13-2015, 02:43 PM
00duvall's Avatar
Default which filter ...40 micron or 10?
I have a aeromotive stealth fuel cell with the a1000 pump that has a 100 micron filter before pump. Looking for filter size after pump. Should it be 10 or 40. I seen that 40 is as low as u can go for a stainless screen.Car will be on e85 also. If any vendors want to point me out one on there sight that would help Or a member point me in right direction. Plus i need a boost reference regulator. I run -8 an ptfe line to and from cell.Thanks
Old 02-13-2015, 05:53 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Fuel injected applications should run a 10micron or finer.
Old 02-13-2015, 06:33 PM
NastyN8's Avatar
This is what I have. No runtime on it yet though. -8an 10 micron stainless mesh.
http://www.golanproducts.com/filters.html
Old 02-15-2015, 09:02 AM
.boB's Avatar
I use these from Summit Racing. 100 microns before the A1000, and 10 microns after. They work well, and replacement elements are easy to come by.
http://www.summitracing.com/parts/sum-230115/overview/
Quick Reply: which filter ...40 micron or 10?
