part# of 02 pin yoke
Old 02-13-2015, 08:37 PM
RyanSws6's Avatar
Default part# of 02 pin yoke
Tired of rear leak. I've replaced the seal with the "new" design 2 part seal with OE GM part and did it right and still leaks. I'd like to replace the pinion yoke with a new one as this rear has about 200k and zero noise...so don't want to mess with a good thing there.
I looked up some part #s at rock auto, any help? Yeah I figure its the more expensive one...
USA STANDARD GEAR Part # USA41088 More Info Yoke; Mech 3R; w/Triple Lip Design; 2.556" snap ring span; 1.125" Cap Diameter; Inside Snap Ring; uses clips; 2.556" Snap Ring Span, 1.125" Cap Diameter
Rear; RWD; GM 7.5" & 7.6"
USA STANDARD GEAR Part # USA41090 More Info Yoke; Mech 3R; w/Triple Lip Design; 2.556" snap ring span; 1.125" Cap Diameter; Inside Snap Ring; uses clips
Old 02-14-2015, 06:13 AM
FirstYrLS1Z's Avatar
For reference:
Yoke 98-02 GM#7827670
Seal 98-99 GM#26026792
Seal 00 1st design GM#26026792
Seal 00 2nd design GM#12471523
Seal 01-02 GM#12471523
Quick Reply: part# of 02 pin yoke
