Converter install troubles
I'm putting a converter into a 4L80E. The trans in brand new and so is the converter. I have installed converters many many times and I work at the shop the built the trans and converter.
For some reason, this converter does not want to seat into the trans. I can get about 3/4 between the bellhousing and pads on the converters. I know it needs to drop again but I can figure out why it won't. IT seems to be moving the pump gears when I pull the converter back out. Are these known to be a difficult install? Anyone have a trick for this? Or know something that I don't?
The aftermarket internal piece in the converter that slides over the O ring on the input shaft is too small. You need to cut the converter apart and machine the hole bigger. Use a stock part to get the correct dimension. Happened to me.
Thanks guys.
I ended up bringing the converter back into my work. I dropped a complete 4L80E pump and input into it and it fell in with no hesitation. Just a case of me being on the other end of a frustrating converter install for once. I'm usually on the phone talking the customer through it.
It may have been a blessing. I decided to build a 245mm instead of the 265 as I think I won't get 3800 stall the way I want with the 4.8ls and 75 billet wheel combo using a 265. Plus it's probably a weight loss of 10+lbs
